kentb
I am building a RV9A with IO-320 engine. I will be installing the induction alt. air into the filter and the other door below the TB if the filter gets clogged. Both doors will be operated by pull cables.
While flying I would pull the alt air knob if condition are right (supected ice, rpm,map drop). The other emergency knob would only be pulled if the filter got cloged up and the engine was getting starved for air.
I am putting in the standard engine controls on the F-746 with the alt air on the left.
Question: were should the emergency air knob be placed? Has anyone flown a plane with a simular setup?
Kent
Kent
