Tobin, almost everyone in the aircraft piston engine industry has "been working" on the diesel alternative.
I too have been interested in an experimental diesel option considering the efficiency, high torque, and availability of diesel with the largest downfall being weight.
While on this subject, I cannot reconcile why manufacturers rate engines in hp instead of publishing torque. If I remember correctly, power loading is measure in lbs of force of thrust produced versus aircraft weight. Additionally, the ability of an aircraft to accelerate is the difference of thrust required (drag) from the thrust available. Especially in the case of a constant speed prop, I think that engine torque is a more meaningful statement of thrust. Assuming steady state, an angular velocity at a specified resistance (blade drag) is the amount of work required or torque to create thrust. Please correct me if I'm wrong.
I just think to be comparing apples to apples, we need published torque values of lycoming/continental engines to be compared against torque values of diesel engines of interest. With that information, thrust specific fuel consumption can be compared, and relative efficiency of each engine as well as peak engine efficiency settings can be determined.
However, it is possible that I'm missing something since reciprocating engines in aviation have been rated in terms of horsepower for as long as I can remember.
Feedback appreciated.
Maybe the consumer is more comfortable/familiar and its a carryover from the auto industry or somewhere...
This one has to crop up every 6 months or so it seems. Hp is a measure of work or the rate of energy release, torque is simply force which by definition is not work- you have not moved any mass over any distance over any time period.
Diesels don't have higher torque than than similarly sized SI engines running similar manifold pressures with the same number of power strokes. If you can provide any example that counters this statement, please produce the evidence. Most modern diesels "appear" to have high torque only because they are turbocharged and running considerable manifold pressure and people compare them to atmo (normally aspirated) SI engines.
So the reason why all engine manufacturers rate their engines by hp rather than torque is because hp is the meaningful way to compare the ability to do work.
Thanks for the response
Not sure if I buy this one completely.... work is the integral of force over a distance. Torque is more than a force, it is a force at a moment. In this case, its the integral of one revolution of the engine (2 pi radii). If the engine isn't turning, or we are using tq to tighten a static nut, I buy your argument. Moving on...
I understand your concern to keep certain factors constant, however consider ambient pressure and temperature rather than manifold pressure constant.
All things equal (piston area, stroke, engine speed), cylinder pressure is the biggest factor for tq. Granted gasoline is more energy dense than diesel, a higher compression motor will have higher cylinder pressure. Where the trade occurs between gas and diesel, I'm not sure.
The real advantage of diesel is in the form of forced induction/turbocharging- you cannot have 'artificially' high torque. Why limit ourselves to natural aspiration? The limitation of gasoline is in the form of knocking or preignition/detonation. Diesel allows us to cram more fuel/oxygen into the cylinder and ignite it in a more isentropic manner with the addition of reclaiming spent exhaust energy. IF it can be done light enough, I think it can outperform gas reciprocating engines in the category of power loading due to the fact thrust is based off engine tq.
My 2 cents.
I think diesel / jet A has a bright future in GA.
I agree.
As long as I can land at most any GA airport and purchase it from a self serve island 24 hours a day.
Ross, you say that when a reliable, equally affordable, similar power-to-weight ratio diesel is available, it would be a viable replacement. Well, I'm flying one every week. My WAM 120 cost no more, and weighs less than an O-235 Lyc of the same power. There are 20 or so of us flying with this engine and so far it has proven reliable. Obviously, the fleet has to build time to prove reliability, but we're off to a good start. WAM has done an excellent job of supporting these engines, along with developing higher HP versions. In today's economic climate, this has not been an easy task, but their owner, along with so many others (TCM, SMA, DH, Austro/Diamond, Centurion, etc), knows that it will be worth the investment. I'm grateful for these forward-thinking pioneers.
Kurt
My point was mainly that none of the 4 stroke aero diesels have delivered on the promise of lower overall costs-acquisition, maintenance and operating and superior reliability/ longevity to date. WAM has done better than the big manufacturers but with a much smaller fleet flying and no substantial flight hours on any of them, long term reliability is unknown. A few hundred hours on a handful does not really tell us much but is at least encouraging and I salute WAM especially for what they have done and all those who are trying new and different engines in GA. We will never have a new bar if everyone flies the same old stuff and we can learn as much from failures as successes.
I'd still be interested in comparing fuel burn/ TAS on an O-235 RV9 vs. the WAM. From what others are reporting here and Van's numbers, they seem pretty close to your's. Have you had the opportunity to fly a trip side by side with one? I see some people getting 135-140 knots on about 5-5.5 GPH. The new IO-233 LSA is down to about 4.5 GPH at 65% power and is quite a bit lighter than the O-235.
Certainly Jet fuel will be with us longer than leaded avgas and diesels will be well positioned to continue to fly no matter what happens with the "new" avgas supply.
