If you're using the I-terminal (small threaded post) for a starter indicator light on the instrument panel, switching the wires on the main posts may cause the I terminal to be on (+12v) whenever the master switch is on (instead of when the starter is engaged).
If you're not using the I-terminal, then no issues. ;-)
