Thanks Bob, I ask because I plan to deviate from the standard setup that Van designed the -7 around back in the day. If I hang heavier stuff up front (io-390' Hartzell CS prop, etc...) then do I NEED to be sure to put weight in the aft end like battery and stuff. Does the -7 more easily run aft of CG, thereby limiting baggage capacity if I build light up front instead, full fuel, etc...? I know everything is a balance but curious if the -7 has a tendency one way or the other.
