I read on a couple of builder blogs that they ran conduit in order to have a way to run wires from the aft to the front. Can anyone explain this that has done it? There are only holes to run conduit in the side walls that I can see. The only holes that run through the tunnel are for the control tube and rudder wires. No additional holes are in the wing spar so I can only imagine that you have to run the conduit from the from to the side walls to the aft compartment?or is there another routing folks have used? Are there any techniques, run power in one and non-power in another, etc?
