From my CI checklist (I'd be happy to send you a copy of it if you'd like).It's in a Word file, and gets updated with specific dates, hours, and new info every year prior to starting the CI.
Preparation — Inspection Consumables
Oil 8 qts AeroShell W 100 Plus
Oil filter Champion CH48110-1 or Tempest AA48110-2
Oil sample kit Blackstone Laboratories
Spark plugs Champion REM38E or Tempest UREM38E (as needed)
Spark plug gaskets 8 copper gaskets
Alternator belt
Air filter recharge kit K&N 99-5000
Brakes Brake lining replacement kit (Rapco RA66-106); Mobil 1 Synthetic ATF
Tires/tubes 2 - 5:00x5-6 ply, as needed; TBD (nose)
Wheel bearing grease Mobil SHC 100
Cotter pins Misc. sizes, including gear nut size
Gasket lube Dow DC-4
Gaskets Fuel injection inlet, oil screen
Light lubricant LPS-2 or comparable light lubricant for rod end bearings
Greases Aeroshell Grease 6 (prop), Mobil SHC 100 (wheels), heavy-duty general purpose (nose fork)
Safety Wire .020, .032, .040
Preparation — Expendables
Absorbent Materials Paper towels, microfiber clothes
Solvents Hoppe’s 9, mineral spirits, MEK, denatured alcohol, Mouse Milk, Brake Kleen, Anti-seize
Cleaners Detailing spray, wipes, etc.
Time-limited items
Item Last change Next due
ELT batteries (replace every 2 years) May 2019 2021
ELT remote battery (replace every 8 years) June 2020 2028
Altitude encoder & transponder certification March 2019 2021
Not everything is used for every CI (e.g., I do bearings, injectors, and a few other things "on condition" rather than by time or hours), but I have all of these things ready to go.
I also have a gajillion screws, bolts, nuts, washers, cotter pins, AN fittings, you name it, because any time I need some, it's usually more cost-effective to order a bunch more at that time.
And, I have a stock of things on the "ready spares" shelf for things that might need to R&R'd during the year. A spare brake master cylinder, a bunch of O-rings of various sizes, a couple sets of brake pads, a spare spark plug or two, various lengths of hoses, a metric ****-ton of wire in various gauges, etc. Even a spare fuel cap. Anything that might break and I don't want to wait for a replacement part.
I see that I've left off the copper-fiber crush gasket for the oil finger strainer...have to add that this year to the document
