Piper J3
I have a SL40 in my RV-12 per stock installation. The radio had a problem about twenty hours ago and then it went away and now its back again.
The radio has static and the Tx light flickers in rhythm with the static. It also seems to be in rhythm with engine speed. Faster engine ? faster flicker / static. No static and excellent radio operation with engine off. What could be making the Tx flicker on/off other than the PTT switch? I?m at a real lost here. Is there any radio adjustments that would effect this? Tomorrow I intend to remove engine cowl and look for loose plug wire. Would a high voltage ignition spark or bad sparkplug cause this? Problem is happening 90% of the time but about 10% of time radio works well even with engine running.
Any help appreciated?
