Comm/Nav Antenna
TheLutz
I'm New Here
I am about halfway through the slow build on my wings. I am thinking about the com and nav antennas. I was wondering if anyone has had any experience with the wingtip antennas that fit into the wingtips? I they are a viable option I would liek to run the wiring for them prior to closing up the wings.
info in the archives
You might try hitting the "Search" botton at the top of this page and running a search on "wing tip antenna". You will get back nearly a hundred posts on this subject and no doubt your question will be answered quickly. ;)
Sam Buchanan
Wingtip antennas
A couple of my local RV builders have antenna's in their wingtips. I have flown in both. NAV and COM both seem to be just fine. I am planning to put antennas in both tips.
I am running a conduit in my wings prior to closing.....I plan to use a steel fish tape to pull the wire through later. I am running my Strobe wires in a seperate run through grommets away from the main conduit.
Cheers!
