Very interesting discussion, and Paul, I'd like to explore that tip antenna you are excogitaing on (can ya say that in public?!
![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I've been playing with some tip antennas for COMM 1, in an effort to remove the last of my belly whips in the search for speed (or efficiency...or both!) Pete Howell has been the R&D department, along with the local avionics shop, and I have been the beta tester. What I've done so far:
Start point:
Two belly whips
-COMM 1 = Standard CI-122 Comant
-COMM 2 = Comant CI-122SP Loran trimmed for APRS (144.39) and/or Sheriff's SAR (150.025)
One Howell J-pole in the right gear leg
Gear leg J-pole and loran ants were switchable between APRS and SAR Comm (MFG-1701 switch...I think that's the number)
Step 1
Removed 1 belly whip (the SP) and replaced it with a second Howell J-pole in the right wingtip. After playing with several configurations, settled on this one, which came up in a conversation with Pete (me: "hey, what if I loop it up and down to get more vertical polarization?" Pete: "its RF, who knows...could work!")
The bitter end starts under the top lip of the wingtip, about the third nutplate back, goes down around the leading edge then up and down as seen.
With an SWR meter, this tested out quite variable, but it had sweet spots of about 1.2 at 143 and 152 (how lucky can you get!) and works well for the SAR radio and has been very good with my APRS (good hits down to 500' agl and below, where the gear leg jpole stops getting hits at 1000' agl or higher).
OK, so I now can switch the APRS/SAR radios to either of the jpoles, and I'm happy there. Still one more belly whip to clean off the belly, and it has been a tougher nut.
Pete made up a j-pole trimmed longer for standard VHF freqs (actually 127, the center of the 118-136 COMM range). I tried several configurations (same wave as above, inverted V, etc, etc.) SWR tests on them were variable (SWRs ranged 1.2 to over 3+ between 118 and 136, and went up and down multiple times in that range, as you might expect). Performance was poor, with a lot of directionality and aspect issues (heading, angle of bank and direction to station made huge differences in performance).
Pete engineered a "Bazooka" antenna from coax cable, and it was supposed to be more wide-band, but in the end it showed similar performance to the COMM 1 j-pole. Here's a pic of one configuration attempt:
I tried wider spread and various designs...no good luck. They all work in the pattern, but no range, and a lot of directionality.
I was hangar flying with the avionics shop guys at the field, and the boss suggested trying a bent whip hung in the wingtip, and he showed me an L-39 in the shop with an inverted bent whip in the tail that was working. He gave me an old whip, on which I cut down the base enough to fit in my tip. I soldered the center wire of a coax lead to the center post of the whip, and crimped a separate wire to the shield of the coax. I then gorilla-taped the whip in place, and ran the ground wire to the outer rib, in hopes it would act as a ground plane. Here's what it looks like:
The small black wire is the ground, and the large black coax connects to the RG-400 (sorry Paul) that runs down the wing to the radio. The grey and black tie-wrapped wires are for the nav/strobe.
Not much luck here, probably just no ground plane, or perhaps just a lot of blockage from the airframe. Very poor range, despite relatively flat SWR tests in the COMM range (1.5 to 2).
Next thought is to somehow make a ground plane attached to the base of the antenna, and attached to the upper inside of the wingtip. Perhaps an "X" made of two 24" strips of metal tape. Just gotta figure out how to attach the ground plane to the antenna ground, and keep the ground plane clear of the base of the antenna itself.
Any thoughts?
Paul, can I borrow that book (or got a link to it online?)
Fun project, and it sure would be neat to find a solution! Sam Buchanan has been watching our work, and as he said, there's probably a reason bent whips are so popular! They work. Its fun to experiment, but for COMM 1, I want very good reliability, so there's the rub!!
Any better mousetrap ideas?
Bob
