If you would like to play around with Garmin avionics in a kiosk similar to what will it be at Oshkosh, with no crowds around and with a factory rep there to answer your questions one on one, stop by the location listed below between the hours of 9 AM and 11 AM this coming Friday, July 12.
From Brad at Garmin, “Kiosk will have 2 G3X Touch and GTN750. I’ll also be flying in a G3XT/dual GTN equipped 182.”
Please don’t park in the grass. There’s a septic system runoff out there.
Use the maps here (note new road into airport that your nav might not show). DO NOT DRIVE ACROSS THE RUNWAY!!!!! Can’t emphasize that enough…. Bring a chair if you need a chair.
(if you're not into maps):
52F airport,
West side, Charlie taxiway off Airway Blvd,
Look for the cars.....
52F airport,
