Hi,
Thinking about building an RV10, i currently own a comanche 250 with a o-540A1D5 an prop HC-A2VK-1 (the one with the AD). The engine an prop have 300hrs and were overhauled back in 2010. I am told the engine and propeller "should" work but I should consider my comanche prop weighs 63lbs which is 6lbs more that the 2blade hartzell offered by Vans.
Do you guys this is an issue? Should I consider using a different prop? I would love to use as much of the comanche FWF as I can.
