Hello,
when analyzing my EM Data I saw a couple short downwards spikes in my CHT and thanks to the feedback from Rob Hickman it hap end when I transmit with my COM 2.
The antenna is mounted on top behind the baggage area on the tail cone. I routed the RG-400 cable along the vertical baggage bulkhead channel F-1028.
I was just thinking if this vertical portion of the routing could be the issue. I will recheck antenna grounding and conductivity of the RG-400. When I transmit on COM 2 I hear some noise.
Did anyone with the same cable routing witnessed similar problems? I guess I just want to rule out that this could potentially contribute to the issue.
Regards
Michael
Regards
Michael
