rv8r
Active Member
Hi out there!
Does anyone know a cure for this problem:
When I start my RV4 (O320, Ellison TBI, both mags with impulse coupling, Facet electric pump, 3-port Vans Primer system) I have to rev the engine 20 times to get it going. Procedure is 1/2 inch opened throttle, electric fuel pump on, priming while engaging the starter for 3 seconds and waiiiting....
It might be the fault of the Vans priming port-fittings, because they are no primer fittings at all, just AN-fittings with standart open outlets. If I look at the Lyco primer ports I see a tiny hole that will spray the fuel rather than dripping it out as the Vans fitting does. Maybe they do nothing at all for starting the engine?? I'm a little anxious to prime for longer than 5 seconds since I saw what could happen when an engine backfires.
Once the engine runs it is VERY easy to restart, even after 4 hours on the ramp, but the next day it's the same hassle.
Any ideas???
Thanks a lot and cheers from Germany,
Dirk
Any ideas???
Dirk
