cold air intake
crashley
Hi as the temperature of the air entering the carbies is over 120 degree it is like running with the carby heat on all the time has anyone fitted a cold air intake I was thinking of using a couple of intake ducts and and ducting the cold air to the air filters
The original RV-12 prototype (Yellow) was flight tested with a cold air intake and just straight filters for comparison.
There was a performance difference, but not significant, so simplicity was chosen instead (no pilot controlled carb.heat needed, lower cost, etc.)
If you try it, don't forget carb. heat....
