I originally installed hard fuel lines to the selector valve per plans (those bends around the gear mounts almost convinced me to get my taildragger sign-off!) but I never liked the install. Lucky for me, they were both accidentally bent where they protrude from the fuselage (freak wind storm collapsed my big shop door and tore up EVERYTHING in the shop EXCEPT the project! Lines were bent in the frantic move to the garage, but I can say my fuselage has already done 60+ mph)
Long story short, I am thinking about using a bulkhead fitting at the fuselage and running flexible hose from there to the outboard cover support and installing an inline fuel filter between that support and the selector valve (one filter per side). Since this is not a pressure application, how do you guys feel about using automotive braided rubber fuel lines from the bulkhead fitting to the filters? Of course, supporting the filter and securing the line to avoid abrasion are things I will have to consider.
Your opinions are anxiously awaited!
Roger
-9A QB airframe (almost) done, ordering finishing kit this week
Roger
