Need some help, hopefully someone else has figured this one out under similar circumstances.
Configuration:
Garmin GMA340 Audio Panel
Garmin GNS430W Navigator
With both pilot and copilot using Bose A20 headsets, everything comes through fine...sidetone, ATC, even music via the external input to the audio panel
When the pilot uses an A20, and the copilot uses a Bose X, the copilot cannot hear ATC or music; pilot can, loud and clear. Sidetone for both is fine.
What the...? I've messed with everything message on the panel and headsets, I think...everything is in stereo mode, squelch is good, I've twiddled and frobbed all the volume knobs (headset, 430, audio panel, XM receiver) to no avail.
Any help will be much appreciated and save me from trading in the "guest " Bose X headsets for another pair of A20s .
Configuration:
