Has anyone used a closed end countersink pull-rivet to fix an oozing rivet? If so what rivet did you use? I have one oozing and have tried numerous times to use Locktite 290 and a syringe with rubber ring on the end so as to pressurize the Locktite into the rivet. So far I havent gotten it to work.
Ed
Ed
