[email protected]
![picture2lo9.png](/proxy.php?image=http%3A%2F%2Fimg167.imageshack.us%2Fimg167%2F7439%2Fpicture2lo9.png&hash=e094991ce9ac77f9c703e1df88193f0a)
started the day chasing down an obvious leak in the left tank... after searching unsuccessfully for some sign on the outside we pulled the tank from the wing and found that several of the ?closed? end pull rivets for the z brackets at stations 5 and 6 were not so closed after all. these special rivets have a partial depth mandrel that does not penetrate the rivet but air was bleeding through the pulled mandrel hole!
it is a bit of a concern that these closed end rivets are not a sure thing.
most of the builder sites that i have seen do not show proseal coverage over these rivet heads... as a preventive measure it would be advisable to go ahead and enclose the heads with proseal.
we cleaned everything up and sealed all of the closed rivets with proseal and pulled the right tank and did the same.
