I've used the search tool, read all I could find, but still don't know the correct answer. The brake cylinders and fuel pump (and probably lots of other places) need the fittings to be clocked a particular way. Using Loctite thread sealant, when I achieve what seems to be a reasonable torque, the clocking is nowhere near correct. Clocked correctly, the torque is too little and I dare not try for another full turn lest I strip the threads. What's the solution?
Thanks in advance.
Jerre
Thanks in advance.
Jerre
