tdavis1198
Active Member
Some builders use Tank Sealant to mount the static ports and Cleaveland suggests you use RTV Silicon. Any reasons why to use one and not the other?
If you use ProSeal, it will take longer to fully cure than RTV. Works great, but it does need to fully cure. Upside is that it’s paintable and won’t contaminate a surface like RTV will.
When people mention the RTV adhesive is that the black RTV adhesive silicone. If so, I have some and will likely try it tonight.
Report on its success pending!
As a new builder I get very confused as to when to use the various different adhesives/sealants. Added to that every person has personal preferences from experience, accessibility and budget. Anyone know of a guide to the uses and properties of products like pro seal, jb weld, RTV silicone, epoxy, etc.
