BravoPapaVA
I'm New Here
Hello all, first post, new member.
I'm a newbie with air tools. I'm starting the practice kits using the Cleaveland empennage get started tool kit, including a Cleaveland 3X rivet gun. I put a few drops of oil in the air inlet per the instructions, and it worked correctly for a few seconds. Now the air just bypasses out the exhaust of the gun. There is no piston action. The rivet set just pushes out against the spring once with each pull of the trigger. Following suggestions from other threads here, I've beat its backside on the workbench and have puts lots more oil in it. No results (other than an oily and dented workbench!)
I haven't resorted to the suggestions of dismantling the rivet gun to remove crud buildup, etc. This rivet gun is brand new, it must be me. I've tried the recommended 90psi and other settings.
It's Saturday, and I can't stand waiting until Monday to call Cleaveland!
I would appreciate any suggestions.
Bob P
Bob P
