fly.more.work.less
Member
Having spent wayyy too much time reading and thinking about how I'm going to prime the internal surfaces, I've decided to go down the Stewart Systems Primer/Sealer path.
A common recommendation regards surface prep is to use Dawn to remove oils (in this case, prior to using the SS EkoEtch).
I can't find Dawn in any of the shops nearby, so would like to know, does Dawn have any particular characteristics that makes it better (for this process) than other dish-washing detergents, or would I be fine using any off-the-shelf dish-washing detergent (such as Morning Fresh, Palmolive that are common here in Oz).
