cjensen
I have a CHT split between the two sides of the engine...Cyl's 2 & 4 are running 60-120 degrees cooler than Cyl's 1 & 3, depending on the power setting. All temps are well within limits, but it's a curious thing to watch. Each cylinder on each side is within 15-20 degrees at all times.
I have the SJ cowl and plenum, and the oil cooler is off cyl 4. That sort of leads me to believe that since I have more exit area on that side, that the temps would be lower than the right side because the exit area on that side is limited to the cylinders and cabin heat air inlet off the rear baffle.
The EMS is an MGL Enigma, and I haven't calibrated the CHT probes...something I intend to do this week with our Alcor calibration tester at work.
I have 15 hours on the engine now, using a quart every 3-4 hours, so the guys at work have told me that it's possible the left side rings are seated, and right are not yet...weird, but could be I suppose.
Any thoughts on this phenomena?
