jcaplins
I would like to re-ask a question about ring terminal spark plug temp probes for a different purpose. Originally asked here:
http://www.vansairforce.com/community/showthread.php?t=157048
Would these spark plug temp probes installed on all 6 spark plugs provide any useful data? I would only be concerned with the delta between each.
If each cylinder is not getting the same air/fuel mix would we see a delta on these probes?
If the answer is no, then this experiment is most likely dead.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If yes, then could the delta data be used to trim the fuel for each cylinder? (Which seems like it will require upgrading to dual EM5 ECU, which may be cost prohibitive at this point.)
The EZ30d only has one exhaust port per side, so the only EGT and AFR I get is left and right. I see no other way to see what each cylinder is doing.
