MartySantic
For those of you that have the CHTs connected, disconnect the left one and see if the left CHT (pilot side) goes downscale. Try the right side CHT. THEN, post your result.
John Bender and I found them misconnected. Our wire colors at the 25 pin connector match.
Hopefully a Dynon change can be implemented with a few keystrokes vs. messing with the 25 pin connector which is heatshrinked.
John has made calls to both Van's and Stein. We cannot do any further troubleshooting because a detailed schematic diagram is NOT available. Another example of why Van's should make it available for the RV-12.
