for temps that are close-- like these. Why not try changing the location of the cht probes to test whether the temperature (if not at least the trend) moves with the probe?
This type of troubleshooting is routinely done in larger aircraft and works well to differentiate between broken parts, faulty wiring, rigging, adjustments etc.
Bill,
If you are talking about moving the probes to different cylinders, that is always worth a try. (For those who do not know, the cylinders have a threaded receptacle for the CHT probes, thus there is only place to install them on each cylinder.) However, as closs as the temps are, they are probably OK.
After that, I would try:
1. Cleaning out the flashing between the cooling fins on the cylinder heads
2. RTV any gap in the baffles
3. Add the aforementioned washer behind cyl #3
4. Block the space under the cowl inlet ramps so air cannot pass under them (I used blue Great stuff foam, worked great)
5. Make sure the airseal fabric is sealing (Look at the top of your cowling for where it makes contact, that is a good ?tell?.) and adjust as needed
6. Put some aluminum tape on the front of cylinders #1 & #2. This will force some air up over the front cylinders and into the back.
After going through all that, I was able to get all my cylinders down to between 174 to 178*F.
