CHT probe installation?
rv6ehguy
Patron
Good day folks,
I am about to install my CHT probes on my engine. They are the type that screw into the cylinder boss. I was wondering if it’s prudent to put a little antisieze compound on the screws? Would I use the same antisieze for the spark plugs? Thanks for your time.
John Van Lieshout
RV6A QB 85%
AeroSport Power IO-375 M1S 195hp
Garmin G3X Touch 2 screen suite
(Looking for a prop)
Antisieze
You want heat transfer from cylinder to the CHT-probe and antisieze.
I use the copperbased antisieze for sparkplugs.
It is also possible to use thermal transfer compound from electronics shop.
Just be sure it has the correct temperature rating.
Good luck
