yankee-flyer
Had a lot of carbon deposits on my plugs during the CI. Either I'm using too much choke or carbs are set too rich. Per the POH, I use full choke to start, then slowly reduce the choke to about 1/2 inch and leave it there "until warm" which I take to mean 122 deg oil temp (i.e right before runup). Thoughts from those with more than 71 hours Rotax experience will be hreatly appreciated.
Wayne 120241/143WM
Wayne 120241/143WM
