GAHco
I first put this in classifieds, but then I found the tools section.
I'm still kinda new at this. Anyway it will probably be more visible here where there is less clutter.
A manufacturer sent me some samples and I put the ZA-92S2 Air Swivel with side valve on my angle drill. What a difference, no hose interference or stress fighting the hose over your arm or shoulder.
Full swivel in virtually all directions. I use my right angle drill in difficult situations, the air swivel makes it even easier. The side valve feature made it so when I needed to limit the air and go slow I did not have to go back to the wall regulator to change the pressure.
I put the ZA-922 on my 3x Rivet gun and it made that easier to use also.
I can get it in tighter areas than before.
After I used them a few times I called them up, and now we stock all the 1/4" npt air swivel that they offer.
Here is a link
http://www.gen-aircraft-hardware.co...es -> Tools&menuID=195~196~196~197~197&id=199
or you can go to www.gen-aircraft-hardware.com
Under the menu on the left side
Tools
Air / Pneumatic, Tools & Accessories
Zipp Tool / Air Swivels
PS. We should have Souix Tools in stock in a month or so.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here is a link
Tools
