petehowell
My new toy arrived from the orient on Friday, so after flying today, I pulled the cowl and got some shots. The $11.34 with free delivery was worth it in entertainment alone - my wife just laughs at me......
Here is the gizmo rigged up - 5.5mm head. Stick in the lower plug hole, then tug the wire to articulate the camera and lights at the cylinder wall or the valves. Rotate the "control stem" to get he angle you want. LED's can be varied in output at the control pad. Push the button to take a pic. I use the "cheese" webcam utility on Linux Mint 17.3 - plug it in and it just works, no software install required. Can shoot video if you are into that sort of thing.
Easily comes out fully doubled over or let it extend straight and remove.
Some Valve Porn - not bad for 11 bux!
Seems to be on sale now. http://goo.gl/BA8OJ6
