MS19087
I've read of several RV14A builders installing the Hartzell Composite prop in lieu of the recommended Hartzell BA Metal prop. I'm not sure of the weight difference, suspect it must be at least 10 lbs. What have builders done to insure that CG remains within spec when installing the composite prop?
Thanks!
Thanks!
