Starting July 1, 2020, applicants for C of A on their projects must upload all documents through the FAA applicant portal.
https://awc.faa.gov/AWCExternalApplicant/Splash/Index
I am a MIDO and FSDO DAR, and request applicants that want me to inspect their project send me the documents first, I check them for errors, and then return by .pdf to the applicant for uploading. There are issues with the new system, hopefully will be worked out soon, meaning sometime in the next 12 months or so. Errors on the documents can delay the processing of the application and the assignment of a DAR of ASI to inspect the project. Soooo, if you don't speak computer, or do not have a scanner that can save as a .pdf,
perhaps check with your local library (post Covid19) and see if they have one you can use.
Regards,
Gary Brown
DAR-T
DAR-F
Regards,
Gary Brown
DAR-T
DAR-F
