Well, an exciting day is coming to a close...we weighed the beast (which means we're real close to inspection time) and got the following numbers.....
Left: 531.31lb @ 69.25" aft of datum (datum is 70" forward of leading edge)
Right: 534.62lb @ 69.3125" aft of datum
Tail: 79.37lb @ 249.625" aft of datum
Soooo, we have an empty weight of 1145lb @ 81.78" aft of datum which seems to be fine for cruising and solo aerobatics (I'm ~175lb), however as soon as I want to go upside down with a likely suspect of adult size I've got a CoG which exceeds the aft aerobatic CoG limit published by Vans (84.5" aft of datum) and only doing aeros on my own has absolutely zero appeal.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have an RV7 with Aerosport O320 with sensenich FP prop so I s'pose I could consider a CS prop (more $$
) - for those that have made this change how did it affect things??
Also have dual LSE Plasma II+ ignition, dual PC680 batteries and SkyTec 149NL starter.
Any other ideas??
Any other ideas??
