Center section wires between pushrods?
Vlad
We are organizing wiring runs behind center section and slowly moving forward learning on the way. The vertical bunch of wires (cockpit lights, ELT etc) - how it goes up? Between pushrods or around left one? Sorry no pictures.
Also how much loop is needed for comm wire? The same location under center section.
There is a drawing (don't remember which one) that shows the wire bundle going vertical between the 2 push/pull tubes, and then up through the snap bushing in the middle of the center section channel. It is shown tied off with a single tie wrap looped through both the holes the Push/Pull tubes pass through.
