alpinelakespilot2000
Drawing 16 calls out for the predrilled holes in the front and aft center sections to be drilled out to 5/8" for a bushing. However, when I started to drill I noticed that if the hole is any larger than 9/16" it will cut into the center section side supports. The plans do note that the flange of the bushing will need to be trimmed (or inserted from the inside out) but neither of these options will allow the bushing through this hole so long as the edge of the side support is not cut out as well. The plans say nothing about "notching" out the side support itself. What am I missing?
(I am drilling with a unibit so there is no way I enlarged it off set from the original. Moreover, I measured the other side that I have not drilled yet and drilling that side to 5/8" would lead to the same result.) See picture for a visual...
Thanks for any help.
