RudiGreyling
HI Guys,
Busy with the center fuse baggage floor and you get 2 corner ribs that is not pre-punched. From the part number looks like parts from a RV6. Aren't we spoiled...
Anycase the plans are not very clear on this, tried Dan's site but I still don't get it. Currently the rib sits on top of the F705. How much do I trim, and do I trim both sides. Does it have to clear F705 completely, does it sit next to it flush and the spacer goes on top of both F705 and the corner rib? What about the aft end?
For Reference:
Dan's excellent site shows the following: (Thanx Dan)
Anybody remember what they did here?
Thanks in advance,
Kind Regards
Rudi
For Reference:
It was trivial to drill everything, with the exception of the corner ribs. Not that it was hard, but they weren't pre-drilled. So I had to trim both ends of each corner rib (the plans were extremely vague in this regard), position and clamp 'em, and drill. I also drilled the "attach strips" that appear to transfer some load on the fore/aft ends. The strips needed minor modification to fit perfectly.
Thanks in advance,
Kind Regards
Rudi
