jsharkey
For those of you that used the RV6 vertical "center console" channel - where did you place the throttle, mixture and carb heat controls relative to each other?
Is one configuration more convenient to fly than another?
I have a fixed pitch prop and plan to have the throttle, mixture and carb heat at the top of the channel with electric trim, electric flap and emergency air controls below them in that order.
I notice that lots of layouts have the controls arranged horizontally across the lower edge of the panel.
Jim Sharkey
RV6 Finishing Up
Jim Sharkey
RV6 Finishing Up
