Dennis Harm
Active Member
Hi everyone, installing the circuit breaker panel into my 14a. Panel was built by Steinair and is being installed into the Vans 45 degree panel kit. When I installed the breaker panel and checked for continuity between panel source wire and ground ,I’m getting a dead short thru volt meter .some part of the buss bar or circuit breaker’s are making contact with the mounting brackets. Did anyone installing this setup have problems with this?thanks Dennis
