Sid Lambert
Did most of you guys put a panel mounted circuit breaker on the B lead of the alternator?
I'm thinking of moving that wire so it's not in the cockpit and using a B and C current limiter.
I will have a 5 amp field breaker and switch to disconnect the alternator if needed.
