pmccoy
I am working on my list of items to wrap up before closing my bottom wing skins. I decided to finish off my QB fuel tanks, which includes installing the cover plate, fuel level sender, drain valve and pressure testing.
Searching other posts I have pretty much decided to throw out both the cork gasket on the cover plate, and the rubber gasket on the fuel sender cap. I will use lots of proseal on both including the screws.
My question is on the CAV-110 drain valve. I can't seem to find any info on whether these should be prosealed as well? Any comments would be appreciated.
