Caution: master relay diode
russtwa
I'm New Here
After burning up 2 control panels, working with Van's the diode was found to have been made incorrectly. I would suggest that those of you that have not used their diode, please check to be sure that it is wired correctly. Mine had the connectors wired backwards allowing a dead short to burn up the control panel master switch.
