pilot28906
I have the Catto 3 blade prop with their carbon fiber spinner. I also have a 20 lb crush plate. I can not get the spinner to fit with the front spinner bulk head from Catto. I have the prop, then crush plate, then front bulk head. The spinner at the rear bulk head is short (does not reach the screw holes). If I put the front bulk head behind the crush plate, the front bulk head flange hits the prop blades. How has others made this set up work. I will call Catto again tomorrow but I must be missing something. Thanks for your help.
