Mel forgot to mention that this three bladed prop is really sexy.
.....A sensenich is 2650 approx RPM... Which is someone more likely to inadvertantly hit?
The Sensenich 70CM series Sensenich for 150-160 hp engines is certificated and limited to 2650 rpm.Only some Sensenich props on some engines have that restriction...others have no such restriction. The FP Sensi is still happily flying on my old 360 powered RV6 after many years with no such RPM limitations.
Just a point to keep things factual. I do look forward to flying behind the 3 blade Catto on the RV9 though!
Stein
Use the torque value on the hub of your prop. Mine was 35 ft-lbs, not 45....The torque value is 45 ft lbs which is a lot closer to metal than wood...
I think only the 3/8" bolts are 35 lbs... and yes I would re-torque these.
4.) The catto prop does pit in rain without the prop guard installed. If you install prop guard, use vortelator strip to get back the perforance lost by the guard. You only lose a little, but the vortelator tape gives it back to you at the hub.
A big pro is it makes good looking and not expensive wall art. You just have to find right wall
I just installed the prop guard tape yesterday and did my first flight today.
The glossy tape is very apparent on the prop rotation.
Should I rough it up and apply a flat black paint?
If so, what is recommended?
Scuffed up tape today and painted with flat black.
Will test fly it when the stinkin' heavy gusty winds stop.
FYI - Call Craig, he is soon to release metal leading edge strips for his props.
Is this a retrofit? My 3 blade is 6 months old, no tape. Does the prop need to go back?
