What is the max rpm for a Catto 3 blade prop in level flight ?
N N184JG Well Known Member Oct 18, 2009 #1 What is the max rpm for a Catto 3 blade prop in level flight ?
burgundyja Well Known Member Oct 18, 2009 #2 3200 mine says 3200 rpm max on it. why do you ask? are you thinking of running it that fast
pmccoy Well Known Member Oct 18, 2009 #4 My Catta for RV9A Here is the data plate on mine. RV9A, Lycoming IO-320
N N184JG Well Known Member Oct 19, 2009 #5 burgundyja said: mine says 3200 rpm max on it. why do you ask? are you thinking of running it that fast Click to expand... Just setting the limits on my VM1000C.
P PCHunt Well Known Member Sponsor Oct 19, 2009 #6 Wouldn't it be better to set your engine overspeed limit? Assume it would be lower than the prop limit....... N184JG said: Just setting the limits on my VM1000C. Click to expand...
