RV-4 w/180hp
I have the Sensenich metal prop on my RV-4. It was relatively smooth until I did a dynamic balance. Now it's better. I mostly fly from paved runways. Climbs at 2450-2500 rpm indicating 125-130kts. In level flight, solo, it will turn over redline at full throttle by about 150rpm. Therefore, to cruise under the redline, power must be pulled way back. Unfortunatley, there is only 1 choice in pitch from Sensenich with the RV-4/180hp combination. I prefer the looks of the 3 blade props, but I also like the low maintence aspect of a metal 2 blade. I'll be checking to see if a re-pitch is possible on my Sensenich. The Catto may afford more options as to custom pitch.
Tim
