RudiGreyling
Hi Guys,
I am bussy with the rudder pedal assembly and have some queries since it is the first time I encounter the castle nuts & cottor pins in my assembly:
Here is my Questions Referring the Drawing above:
1) Yellow Highlight: What is the order of the washers? Does the thin AN960-10L washer go between the 2 moving parts or on the outside just under the nut? What is the typical practise?
2) All Castle Nuts: How tight to you make these since there should be relative movement on the components kept in place?
3) Cotter pins: What is the best way to do them?
4) Lubrication: Is any lubrication required on these moving parts?
5) Yellow and Green Highlight: Release notes R1: The specified AN3-5 bolt is to long for the assembly I physically checked, since it only goes through the alu angle , where as the other side goes through the additional brake master Cylinder attachment bracket. The previous specified AN3-4 bolt looks like it would have worked perfectly on this location. How did you guys solve this or do you know why Vans changed in it?
Thank you,
Kind Regards
Rudi
![fuse_25.jpg](/proxy.php?image=http%3A%2F%2Fwww.freepgs.com%2Fflyboy%2Fpictures%2Frv_fuse%2Ffuse_25.jpg&hash=f77e6cf93e215e2544756162ea254ce2)
![rudder.gif](/proxy.php?image=http%3A%2F%2Fwww.freepgs.com%2Fflyboy%2Fpictures%2Frv_forum%2Frudder.gif&hash=2ae71cd839bdf2a643cfb983ec830422)
Thank you,
Kind Regards
Rudi
