I'm talking about the one that adapts to a vertical spin-on, with filter opening downward. How do you drain this filter when changing oil? Does it drain on each shutdown (requiring refill on startup, no oil pressure for the first few seconds) or something else? I've heard reference to punching a hole in it with a pin to let air in and allow it to drain before changing the filter - what's the procedure here?
