David Shelton
The RV-10 looks like an excellent candidate for a cargo pod; large useful payload but small baggage area. I?m working on some new cargo pod designs and I?d be happy to develop one for the RV-10 if there is enough interest. I?ll describe my pods below and I?d love to hear feedback here or at my online survey: http://www.surveymonkey.com/s.aspx?sm=z2hHQ3rpu2gFr3JDVutbrw_3d_3d
In addition, I?d be interested in teaming with an RV-10 owner, providing a free or discounted pod in exchange for evaluation on their aircraft.
Removable Design
Conventional pods are normally designed with working airplanes in mind. Since working airplanes rarely need to remove their pods, they tend to mount with dozens of fasteners like a large cowling. Installation commonly requires a helper and 30 minutes of wrestling.
Personal airplanes have different needs. It is desirable to use cargo pods on certain trips but remove it for routine flights. We?re developing the first cargo pods that are easily removable, providing awesome hauling capability when you need it then converting to a clean airframe when you don?t. The new pods may be attached or removed in as little as two minutes, without assistance or tools.
How does it work? A built-in winch system allows you to hoist the pod up to the belly for attachment and lower it to the ground during removal. The attachment hardware is self-aligning and the pod is secured with four quick-release pins at reinforced attachment points.
Top-Loading
Conventional cargo pods may only be loaded through a door. These pods add considerable payload volume but they will not accept any cargo that is larger than the door. Our cargo pods may be easily removed for top-loading of larger items such as bicycles or deer! After loading, the integral winch system is strong enough to hoist the fully-loaded pod back up to the belly for reattachment.
Optional Motorcycle
These removable pods were originally designed for the purpose of hauling street-legal motorcycles. We have developed a 225 lb street-legal motorcycle with a reliable 4-cycle engine, electric start, highway performance and two-up riding. It quickly folds to a width of 12 inches and stores on its side without leaks. Within minutes of landing, it is possible to extract the motorcycle, unfold the handlebars and ride away. The motorcycle provides fun and convenient ground transportation at any airport and makes new cross-country adventures possible. It?s a great way to ride into town, reach new places or explore your destination.
Construction
Vacuum-bagged composite sandwich construction. Aluminum honeycomb is utilized in the floor for durability. Mounting rails will accept movable tie-downs, dividers, ski racks and other accessories. Optional NACA vents are required for motorcycle storage. A pod for the RV-10 would likely weight about 45 pounds with a gross weight of 300 pounds. The additional drag would reduce cruise performance by 6-8 knots.
Removable Design
Top-Loading
Optional Motorcycle
Construction
