Carburetor fuel inlet screen- Avstar
Kato's 8
Does anyone here have experience removing the carb fuel inlet screen from these new Avstar carburetors supplied on the lycoming o360 engines? They look the same as the Marvel ones they replaced but there isn't a copper washer with the finger tabs bent over a nut flat like the marvels on the opposite side of the inlet connection. There is a slotted bolt head next to it with that type of copper gasket but it's not in line with fuel inlet.
Washer
The washer/gasket that Spruce sells does not appear to be copper. It is a plain washer with no tabs. IIRC the tab washers are used only on the screws that hold the main body halves together.
Thanks. I figured it out. It is the opposite side from fuel inlet and it's the hex bolt. Screen comes out with it as an assembly. No the washer is just a flat washer with no finger tabs. Just tight fit only.
