Grumpy-Hodge
Member
Hey all. I plan on using the Andair Gascolator on the RV-9A with an O-320. Is a fuel filter(s) installed somewhere between the wing tanks and the Facet pump a requirement, highly desired, or a good suggestion? I dont believe any of the certified tin cans I have flown have filters other than the Gascolator.
If installed, which filter is recommended?
Is it okay to run hose with aircraft-grade clamps between the wing fuel pickup line and the Fuel Selector valve along the front of the carry-thru spar or not? It seems that if a filter is installed, then one for each wing feed would be better than a single-point of failure.
Part numbers will be very much appreciated.
Thanks in advance for the help.
